Another clutch problem after swap
  • Sharino
    • Jun 2005
    • 186
    I installed a M50NV into an E30 from a late 1990 525i.
    I used the clutch/pp/fw attached to the M50 engine and didnt even unbolt it as it was tested and good when still running in the 5er.
    For transmission I used a Getrag from a E36 325i.
    New slave cylinder for E36 325i.
    When complete, the clutch will not fully disengage, as I push it towards first, the car will start rolling and it is quite difficult to get it gear.
    Foolishly I assumed the M50 clutch and flywheel/pp where the same on E34 and E36 M50s. I found out later it is a different part numbers, could this be the source of my problems?
    any othe ideas?
    www.eurowinnipeg.com
    www.E30S38.com
    E30 Mtec2-S38 | V10 TDI treg | E34 M5 | E39 M5 | Corrado turbo VR6
  • nrubenstein
    • 3148
    Does the clutch fork match the clutch? That's my first suspect.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Sharino
      • Jun 2005
      • 186
      It was the fork from the E34 getrag, which would be the same as the clutch.
      I am going to try and remove the clutch pedal stop, not sure if this normally needs to be done. Other idea is to find a way to extend the slave cylinder rod a little bit if I can find a creative way.
      www.E30S38.com
      • nrubenstein
        • 3148
        The E34 should have used a ZF last I checked. That should not be a problem with the slave or the clutch assembly, though.
        How thoroughly have you bled the clutch? If it hasn't been pumped 100 or so times, there's a good chance that it simply hasn't finished self bleeding.
        • Sharino
          • Jun 2005
          • 186
          My mistake, yes it is a Zf in the E34, but I used a E36 Getrag, the flange was the wrong size to connect to the E36 driveshaft I had.
          I bled it with a motive power bleeder as well as pumped the crap out of it.
          I am hoping I dont have to pull it all apart again. I am trying to remember what fork I used, the one from the E34 ZF or the E36 Getrag one but I cant recall.
          www.E30S38.com
