Hi I have a brand new clutch slave I've been using on my G240, but now that my G240 has shit the bed I'm upgrading to a G260. My G240 clutch slave is a wee bit longer than the G260's, what type of problem will this pose? Clutch slippage?
Clutch slave G260
Tags: None
If its longer by a smidgen i wouldnt worry about it as long as its allowed to compress fully when installed. If it bottoms out and doesnt allow the TOB to come off the PP enough your clutch will slip and die. It doesnt really matter if its too long though as the PP assy is designed to only go a certian distance.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno Thread -
