M52 Swap Thread
  • 95///M3
    • Mar 2005
    • 181
    M52 Swap Thread
    Ok, so I have compiled some parts for my swap... help is needed however!
    M52 from 96 E36 328i - I have everything from the donor vehicle; accesories, ews, dme, etc
    Use stock headers or find something off of eBay?
    G260 from E30 - Which custom trans bracket should I purchase?
    Stock E30 driveshaft
    E21 Booster - already modified
    Either REVshift or AKG motor mounts need to be ordered - any recommendations?
    E36 Radiator - fan recommendations?
    Wiring - should I follow the standard pinouts posted all over here or is going to be different with the obd2.
    Use the M52 DME? I have a 413 red label, but not obd1 yet.
    Any help on a few of these details would be greatly appreciated. Will update with photos when I makes some actual progress.
  • MaksV
    • 1042
    This should help a bit.
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
    • 85bim
      • Jan 2011
      • 92
      As for the headers I am running stock OBDII headers with no clearance issues.
      Im using an E36 318i rad. with a Spal 14” pusher fan 1750cfm.
      I used E24 motor mounts, although i wish I would have gotten the ones from AKG as they aren't really at the correct angle so it was a tight fit.
      On the other stuff I went ZF tranny and OBDI swap w/red lable 413 and a chip from TRM.
      Hope this helps.
      • justin_l_
        • Jun 2007
        • 1079
        1. OBD2 headers flow fine.
        2. AKG, but beware the studs may be a little short for liking-still work just shorter than I would like.
        3. A nice spal will work well.
        4. If you are not sure about the pinout use an ETM and check for yourself. You will learn a lot more like this anyways.
        5. If you not OBD1 then you need to use the m52 ecu.
        6. SEARCH.
        • John@Revshift
          • 205
          Either Revshift or AKG motor mounts need to be ordered - any
          I heard that the Revshift swap mounts fit better and are easier to install. They are also made from better materials and they have stronger internal assemblies.
          • mtlbloodshot
            • Jul 2011
            • 761
            If the Revshift mounts are better than AKG.. Why doesn't Guten use them?
            MY BUILD THREAD
            http://www.r3vlimited.com/board/showthread.php?t=235231
            INSTAGRAM : @luchcolaneri
            • Danny
              • 14217
              I like my revshift mounts.
              • Teaguer
                • Sep 2004
                • 6167
                May want to source an E34 oilpan, oilpump pick-up and dipstick tube while you are at it.
                • Jand3rson
                  • 37587
                  Because Guten isn't the only shop in the world? While I think GPS is a great shop, they aren't the standard by which to be measured. No offense to GPS or Levent, but one shop shouldn't be your only reason.
                  • 95///M3
                    • Mar 2005
                    • 181
                    I should note this is not my first swap... I did an S50 swap about 7-8 years ago, and I simply forget everything that was involved.
                    The added complexity of the M52 is what I wanted to clear up.
                    I sourced all of the parts for the OBD1 swap - 2 questions, what chip will go in the red 413 to work appropriately with stock obd1 m52? and the harness I have is from an automatic, I read about some 'modifications' that need to be done. Can anyone elaborate further?
                    Thanks,
                    Jim H.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Stock Chip?
                      Cut off Trans portion of harness?
                      • 95///M3
                        • Mar 2005
                        • 181
                        Stock Chip?
                        Stock M50 chip with the obd1 swap and M50 manifold?
                        Clip it and be done?
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          Yes?
                          Open the harness and take it out all the way to the x20?
