Reverse Lights E30 M50 swap
  • MaxBell
    • 1391
    Hey guys, I'm taking the car in to safety in an hour and I need to know how to hook up the reverse lights.
    I saw in another thread something about the E36 engine harness having an output that has to be wired into the blue/white wire under my shifter? I already have something from the tranny (325e) plugged into the body harness but obviously I still don't have lights.
    ANY help is appreciated, I'm really getting down to the wire here.
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • FredK
    • 14759
    If you use the stock E30 backup light switch and wiring harness, you don't have to run a wire from the E36 engine wiring harness.
    It sounds like you have a bad backup switch.
    • eurosport22
      • 210
      so wait... are you running the g260? if so then yea fredk has it. nothing gets changed from stock.
      • MaxBell
        • 1391
        Ok, so I got under the car and the switch was unplugged. Plugged it back in but still nothing!
        GRAAHHH!!!
        I'll replace the switch and report back.
        • xwill112x
          • Jan 2009
          • 4236
          Ohm check your wires might be snipped somewhere n ya dont know it
          • MaxBell
            • 1391
            According to the ETM the wire comes out of the trans, under the shifter console, hits a plug, then goes to the trunk.
            I had the trans out, could it be that the wires have been switched on the reverse switch? Or does it matter.
            • eurosport22
              • 210
              im pretty sure its just a open or closed switch to complete a circuit, the position of wires should not matter
              • scottinAZ
                • Dec 2009
                • 1312
                position of wires does not matter. the switch is either open or closed. check for broken/chafed wires from the connector under the shift boot to the switch on the trans. not uncommon for them to short out/break and fuck things up
                I saved 15% on my Bimmer parts by switching to ...
                • MaxBell
                  • 1391
                  I checked the shift boot area and it all looked good.
                  Then I check it more thoroughly and found that one of the pins has gotten pushed out of the plug.
                  Resoldier a plug in and it all came alive.
                  • Gooch
                    • Dec 2006
                    • 1674
                    Nice work, thanks for posting the solution. I hate when a problem/issue goes unanswered.
                    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                    '87 535i - Vacuum brake conversion [SOLD]
                    '93 525iT - 5-speed swap - 320k and counting
                    '09 328xi - 6-speed
                    • MaxBell
                      • 1391
                      As do I. I always try to get back and answer when I find the problem. Having good thread titles and posts helps for Google Searches too!
