hi
im unsure about something...
the knock sensors from my m50 don't look good. the knock sensors on the m52 look great! the wires for the OBD2 knock sensors are bigger (diameter) while the OBD 1 sensors are smaller in diameter. Can I just cut and splice the M52 knock sensors to the M50 knock sensor plugs, to create make shift OBD 1 knock sensors?
the same thing goes for the coolant temperature sensor. the M50 has 2, the M52 has 1. can I just use the OBD 2 sensor and plug, and splice it the OBD 1 M50 coolant temp sensors plugs? it will be like making the plug and play conversion kit by Turner Mother Sports!
Thanks
-rob
Thanks
-rob
