What should I do?
  • 325Projectz
    • Jan 2005
    • 1956
    What should I do?
    Alright, more opinions needed!
    Should I spend the money on 24/lbs injectors, 3.5 hfm, and a chip right now? I already have the lightweight flywheel to go with it. Anyone else done this & and what kind of power increase did you see?
    Or should I just leave it stock?
    91 m3
  • joshh
    • Aug 2004
    • 6195
    I would think the chip will give you the best increase in power. But I don't know what you have done to the motor.
    "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
    ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
    • 325Projectz
      • Jan 2005
      • 1956
      Stock s50. I don't have a AFM or injectors, so I figured why not upgrade right now.
      I for sure need the chip for EWS.
      91 m3
      • DEV0 E30
        • Oct 2004
        • 8896
        Twin screw or ban.
        • permit
          • Mar 2005
          • 3363
          HFM and M52 manifolds, get the air going a little better.
          • 325Projectz
            • Jan 2005
            • 1956
            Hmmmm, good idea.
            I'll add those to my list.
            91 m3
            • erik325i
              • Jan 2005
              • 3567
              Do the m52 manifold bolt right on, or is there any modifying needed?
              • permit
                • Mar 2005
                • 3363
                You need to have those extra two holes welded shut where some piping came out of the M52/S52 (something to do with OBD-II, I think), but yes, they're bolt on. They're longer though, almost touches the subframe, so you'd need a bit more custom work if you already have your exhaust set up for an M50. In Sean's case, he won't have to worry about anything because he has no exhaust yet.
                • Addissimo
                  • Mar 2004
                  • 1820
                  Stand alone EFI you waffleswaffleswaffleswaffleswaffles...
                  Doing something M50 related? -> http://www.addissimo.com
                  On Myspace? ->http://groups.myspace.com/r3vlimited
                  BF2142 SN = BillyGoose
                  • aaron_silva
                    • 1785
                    You can also get the exhaust gaskets that cover 3 exhaust ports (so you need two). I heard those work better than the stock ones.
                    Aaron
                    • The Fast One!
                      • Jul 2005
                      • 856
                      TEC3r thats what you need. :D
                      Mike Fritz
                      • Addissimo
                        • Mar 2004
                        • 1820
                        haha- or ms for 1/1,000,000 of the price... either one will work.
                        • 325Projectz
                          • Jan 2005
                          • 1956
                          No standalone right now.
                          Order HFM, injectors & chip.
                          91 m3
                          • NickP
                            • 257
                            you also have the option to disable EWS
                            • 325Projectz
                              • Jan 2005
                              • 1956
                              The TMS chip will take care of that.
                              91 m3
