Motor mount spacers
  • eurosport22
    • 210
    yea i dont like the way that looks. i only put 2 washers on the passenger side of mine. none on the driver side. and nothing is touching on my motor. i would not be crackin into that throttle with that mount torqued like that
    • gp.plus
      • 416
      I believe it's e28 m5 mounts that you want, not standard e28. For reference I'm using the rev-shift blue swap mounts and I needed a thick spacer on each side to clear the booster and the exhaust to frame rail.
      • FredK
        • 14762
        Yeah, it's not a big deal to your driveline. I've run a healthy amount of spacers, and my driveshaft has been fine for the past 32,000 miles.
        • cmybimmer
          • 894
          ^Good to hear :).. Like I said, no abnormal shakes are noticed and it feels stable enough to drive so idk. Plus, I don't see 2 washers doing much difference anyway. Even with the washers I have now, I still have to do some hammering to fit the exhaust so i can just imagine 2..
          • 328ijunkie
            • May 2007
            • 3961
            Your mounts have collapsed. (prob from using crazy washers)
            Check Us out on Facebook
            Full Product Line Tuning
            • FredK
              • 14762
              The use of E28 mounts is not an "engineered" solution. They are merely an inexpensive way to install an engine. They will collapse with or without spacers. I filled mine with urethane to avoid the inevitable "squish".
              • cmybimmer
                • 894
                If anything I'll just take out like 2 washers on the driver side to give a little slack. A new motor mount is $25ish so im not too concerned.
