I'm working on my A/C - I've got it all mocked up... problem is my condenser to compressor hose. It's really long, mostly due to the metal part of the line. The new compressor sits way forward since the new motor has 2 extra holes. the end of the hose is about the middle of the motor.. If I bend it woards the compressor it kinks. I was thinking about cutting my NEW hose and add a 90 deg metal line. I can't come up with an elegant solution that doesn't involve alot of bent metal lines and connectors.
Those of you with swapped out 4cyl's
Tags: None
There are shops that can custom fab a new line for you. -
I know there's one across the parking lot from me...
The 4cyl cars have a line that is about 50% metal, that's the issue... The non-M3 line will not fit at all, it isn't curved properly. I want it to look as OEM as possible not come cobbled together mess. I was hoping someone had an elegant solution but I'm coming up empty handed. I have a few ideas to try...Valley Motorwerks
1988 E30M3
sigpicComment
