m50 swap suddenly no power at pump
  • mo diesil
    • Jan 2011
    • 275
    so my swap has been running for about 3+ years now and about a month ago i went to back out of my drive way and it wouldnt start.
    its a 87 with the 2 pump setup, the pumps where not turning on and i had no tools at my house to check electrical, so i towed it down to my work, put in a 90 e30 pump and so on, car would not start checked electrical and no power only ground to the pump,
    really need help on this one guys its getting tiring driving a stripped down turbo race car EVERYDAY... not exactly comfort,
    any thoughts?
  • singh336
    • Dec 2010
    • 211
    so u got to trace backwards then, see if you have power at the relay for the pump and then check continuity between the relay socket the fuel pump for power etc
    • 10Toes
      Me Father Was A Tree
      • Jan 2008
      • 61222
      Check for power at the relay.
      • mo diesil
        • Jan 2011
        • 275
        im still at work and have yet to actually do anything, BUT FOR what is worth last night the relay was turning on
        • singh336
          • Dec 2010
          • 211
          check continuity between the relay and pump maybe its broken somewhere between
          • hwy84
            • Aug 2009
            • 190
            Crank position sensor needs to see the crank spin before the ecu will ground out the fuel pump relay. If your crank position sensor is bad, you'll get what you describe.
            Current:
            1991 325i Sedan - S50 Swap
            1988 325i Cabrio
            Past:
            1991 M3
            1991 318is
            1985 325e
            • mo diesil
              • Jan 2011
              • 275
              I'm going to fo the cps and relay tonsrrow
