Driveline vibration?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Anyone else have vibrations in their driveline?
    Mine seems to vibrate a bit in lower gears at high rpms, I think my csb may be slightly out of line, think that would do it?
  • DesertBMW
    • Aug 2011
    • 1034
    worn U joints. Then may appear good but when they are under the load allow too much sloppiness
    • Pl3wA
      • 1589
      i too have these vibrations. like decent acceleration in 1st,2nd, maybe 3rd at like 2.5k rpm
      • 328ijunkie
        • May 2007
        • 3961
        None here. How much did you shim the motor?
        Check Us out on Facebook
        Full Product Line Tuning
        • GunMetalGrey
          • Dec 2010
          • 1499
          One washer on the passenger's side at this point, did it without the motor shimmed.
          Going to straighten the csb tomorrow.
          • GunMetalGrey
            • Dec 2010
            • 1499
            Last time when I would tighten the bolts for the csb it would twist the mount on me, would new washers take care of that? They have a bit of surface rust, so I feel like that is grabbing onto the mount plate of the bearing and twisting it when it gets tight.
            Anyone else run into that problem?
            • atmobenzin
              • 151
              Check if all the bolts on the rear end are properly tightened. Mine was vibrating like mad, turned out that one of the bolts that mounts diff to sub-frame was loose.
              • GunMetalGrey
                • Dec 2010
                • 1499
                Yeah, that was a plan as well.
                It only takes one little thing to be loose for some vibrations lol.
                I will work at it and keep you updated.
                • dude8383
                  • Jan 2005
                  • 10387
                  I'm getting some driveline vibration with a swap car that I built... Happens in first gear only from like 1.5k to 3k...
                  Car has an S50 mated to a getrag 260. It only happens when I accelerate from a start quickly... if I get moving slowly it doesn't really happen.
                  • Fusion
                    • Nov 2009
                    • 3659
                    I get vibrations shifting down into 3rd (low DD rpms) and rarely down into 2nd.
                    No idea what it is.
