Best Brake Cylinder
  • robert1700
    • 1151
    Best Brake Cylinder
    In my first DOHC swap what is the best brake package? I have driven three e30's with the M5x or S5x with e21, e30 ix and e34 540i brakes cylinders.Which do people prefer? I have a extra 540i one and I was going to use that, plus its bigger than the rest.
  • 328ijunkie
    • May 2007
    • 3961
    E34 V8 is what i run on everything. Best combo
    Check Us out on Facebook
    Full Product Line Tuning
    • frankie591
      • Feb 2012
      • 545
      e30 slotted is the best option because you already have it.
      Slotting the holes and modifying the clevis took me all of 45 minutes to do.
      • hwy84
        • Aug 2009
        • 190
        ^ This. Though, it took me about an hour. I am clumsy, I guess.
        Current:
        1991 325i Sedan - S50 Swap
        1988 325i Cabrio
        Past:
        1991 M3
        1991 318is
        1985 325e
          • 37833
          I like the E32 735i booster/master with remote 2002 reservoir.
          Grover Beach, California
          BimmerHeads.com
          • 10Toes
            Me Father Was A Tree
            • Jan 2008
            • 61222
            I like my E21 with stock master.
            • eurosport22
              • 210
              i like my e21 with stock master. i have to stand on the brakes a little more when im coming up on traffic at 110 on the highway but normal driving i dont really notice much
                • 37833
                Nothing like worse braking with more horsepower!
                BimmerHeads.com
                • evandael
                  • Oct 2009
                  • 2881
                  i thought that it's not worse braking, it's just more effort. so you just need to work out that right leg a bit more.
                  the best would probably be the e30 ix booster/master with some upgraded rotors and pads. it'll retain stock-like driveability and pedal feel because it was stock. slotting the firewall to use the stock booster makes me nervous, just from a 'hack-job' point of view.
                    • 37833
                    I agree, I am not a "slot the firewall" kind of guy.
                    That's why I recommend (and use) the E32 735i setup. It fits like the iX booster (same) but has a bigger master cylinder. The brake feel is GREAT.
                    BimmerHeads.com
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      ^I run the same^
                      I think it's important to realize though that what you are increasing is your braking system's ability to apply pressure to the hydraulic pistons at the wheels. This doesn't actually mean your stopping distances or resistance to brake fade will change.
                      It takes better pads and larger rotors/better cooling respectively for that.
                      However underboosted brakes are obviously worse than over boosted with too large a master cylinder.
                      It could even be argued that a 25mm master cylinder on stock brakes will make your braking worse because of the loss of pedal travel and modulation that gives you.
                      I personally like the stiff pedal feel, it goes with my z4 short shifter's short crisp notchiness.
                      '89 Alpine S52 with goodies
                      • e30rapidic
                        • 2167
                        I have a 944 turbo booster and 7 series master. awesome
                        '87 325ic, powered by S50.
                        • FARZAD
                          • 257
                          I have e21 booster and the brakes Sucks........
                          • robert1700
                            • 1151
                            just finished and i love the firm feel of the 540i booster and cylineder, by far the best i have felt, way better than the e21 and ix.
                            • yanal
                              • Jun 2011
                              • 248
                              I moved the stock booster and it sucks !!! I'd never do it again.
                              Btw I have e36 M3 fronts and e30 m3 rears
                              Sticky:True e36 one touch windows DIY
                              1990 M3
                              1992 Mtech (S50 + 5 Lug)
