m52b25 or m52b28?! no way of knowing
  • Dirtnap30
    • Aug 2011
    • 58
    ok so this is beginning to drive me nuts. I recently swapped an m52 into my car and its been running strong. however my issue is that I have no real way of telling if its a 2.5 or 2.8. I never saw the car it came out of (sat in my bosses storage container for like 3 years, claims it came out of a 94' 325i....obviously wrong, clearly an obd2 motor) but anyways, the badge on the block is not readable and I NEED to find out cause I'm running a 3.0l turner tune which turner claims is ok for a 2.8. any suggestions?
  • pandaboo911
    • 2070
    There should be a piece of the headgasket that sticks out past the block that lists displacement. It's on the exhaust side next to the vanos
    • 328ijunkie
      • May 2007
      • 3961
      Stamp on drivers side of block
      Check Us out on Facebook
      Full Product Line Tuning
      • Dirtnap30
        • Aug 2011
        • 58
        I've yet to been able to clean the block tag up enough to even read a single digit :(
        • Dirtnap30
          • Aug 2011
          • 58
          just confirmed it, says 2.5 :sad: not stoked right now. I should probably get a new tune asap
          • DesertBMW
            • Aug 2011
            • 1037
            That is not correct way of knowing because all 2.8 head gaskets will have 2.5L on them, even the cylinder heads.
            You got to look at the driver side right by the engine mount on the bottom of the block it will say 28 s 01 if its 2.8l
            Or take one of the spark plugs out and use long screw driver and measure the stroke, 2.8L will have 84 mm stroke.
            • DesertBMW
              • Aug 2011
              • 1037
              This is wrong information, 2.5L and 2.8L share the same head gasket and gaskets are all marked as 2.5L
              • 328ijunkie
                • May 2007
                • 3961
                ^That.
                Take a plug out and put an extension in the plug hole. Measure the stroke while rotating the crank.
                2.95" = 2.5L
                3.31" = 2.8L
                • eurosport22
                  • 210
                  damn i would have made sure i knew all that before i put the motor in. but hopefully you ended up with a 2.8
                  • Dirtnap30
                    • Aug 2011
                    • 58
                    I'm gonna measure the stroke asap and pray its not a 2.5....
