Are all 24v heads the same?
  • Cyrix2k
    • 593
    I saw someone mention that the vanos unit bolts up to a non-vanos head... and indeed it does. The NV has all the provisions there for the oiling system and the timing cover thing on the head is setup the same way as the vanos unit. So, are all the 24v heads the same? Can you swap double vanos to a single or non-vanos head? And it certainly looks that with a couple non-vanos parts and non-vanos cams, vanos could be deleted without pulling the head.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
  • DesertBMW
    • Aug 2011
    • 1043
    Yes they are all the same except later heads have more efficient improvements. But they will all bolt on and work.
    1992- fat valve stems(heavier valve), double valve springs, slightly different CC of the compression chamber
    1993-1995- slim valve stems, single wide springs
    1996-1999- slim valve stems, single tapered valve springs, lighter and smaller valve spring keeper
    I am not getting into camshaft, trays and lifter arguments here
    Best head to get is 1996-1999 and 1992 the worst
    • e30shmobberr
      • 1934
      i wonder if the s54 head on a s52 would work. obviously you would have to change engine management for the additional vanos. just curious, or am i retarded.
      Patrick - IG:niicknac
      RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
      • Wh33lhop
        • 11705
        Why? So you could have a lower compression, lower displacement S54 with crank harmonic issues above 7200rpm?
        The bottom end is not the expensive part of the S54.
        paint sucks
        • 328ijunkie
          • May 2007
          • 3961
          DVanos heads wont bolt on to Single vanos blocks
          Check Us out on Facebook
          Full Product Line Tuning
          • surebimmer
            • Jan 2004
            • 978
            Even some "400" heads are the early design and have less coolant ports. See my pictures. http://www.r3vlimited.com/board/show...light=400+head
            Cracked head '400'
            Replacement '400' head has less coolant ports, same amount of coolant ports as a '070'
            Early Vanos M50 '070' head
            • 5KWattson
              • Apr 2009
              • 809
              but that is assuming the heads are complete stock form, the bare head itself is all the same 93-99 minus the coolant temp sender lack of on the 96-99
              "God created turbo lag to give V8's a chance" Taylor D.
