To all the m50 guys out there: I installed a new intake cam on my m50b25, service information says wen installing the intake cam sprocket to center the bolts that come from the cam in the sprocket bores. I put everything back together per service info but now I cannot remember whether or not I centered the sprocket when installing. I've turned the engine over plenty of times and the timing checks out (used cam blocks etc). If I did not center the intake sprocket would the vanos not fit on properly or would the intake cam not be timed properly? I believe everything is right but now I am second guessing that sprocket.
M50 Cam timing question??
Originally posted by lowdub21 View PostTo all the m50 guys out there: I installed a new intake cam on my m50b25, service information says wen installing the intake cam sprocket to center the bolts that come from the cam in the sprocket bores. I put everything back together per service info but now I cannot remember whether or not I centered the sprocket when installing. I've turned the engine over plenty of times and the timing checks out (used cam blocks etc). If I did not center the intake sprocket would the vanos not fit on properly or would the intake cam not be timed properly? I believe everything is right but now I am second guessing that sprocket.
You will get a vanos jammed code along with possibly bent valves if you advanced it too far.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Yeh, you will have problems, since if the exhaust side was set in the middle properly, the intake will have less movement in one of those directions.
As jrdeamicis said, your VANOS will jam up, you will experience blow by and at worst you may (unlikely it's off THAT much) bend a valve.
Follow the Pelican Parts guide closely and you should be fine.
