E36 M50 4cyl tach help
  • MMontero
    • Jun 2012
    • 6
    Hello
    I have a E36 M50B25tu 1/1995 and i got questions
    The cluster is of a 318 , and the rpms show 66% more than they really are. ( http://www.youtube.com/watch?v=0dAUjR2P5Hg )
    Can i flash , or mod something on the tachometer , so i can get the real rpms ?
    If there is no way of fixing that , can i get a E36 M3 cluster ? just unplug the 318 and get the M3 in ? "plug and play" ?
    -Is my car OBD1 ? , i've seen the 20pin obd near the exaust , but i think that there is no obd2 port near the "gong" , i can access almost all features of the car , ( DME 3.1 ) , but i cant get live data .
    Thank You
  • BBDirtbiking
    • Apr 2012
    • 323
    For the tach problem... http://www.r3vlimited.com/board/show...11&postcount=2
    Car is OBD1.
    "Bayerische Motoren Werke - freude am fahren."
    Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
    • aplinweiss_is
      • Jun 2011
      • 89
      /\ this
      you just need 6 cylinder coding plug for the instrument cluster.
      what year is your 318 ?
      • MMontero
        • Jun 2012
        • 6
        Car is OBD1.
        that works on E36 too ?
        Originally posted by aplinweiss_is
        /\ this
        its a E36 325i 1/1995
        • BBDirtbiking
          • Apr 2012
          • 323
          I have never ripped into an e36 so I can't really say if it works or.not
          If it has a coding plug then most likely will work just switching out your 318 to a 325 plug.
