Hey guys...much appreciation for those who are taking the time to read and possibly help.
I have an s52 converted OBD1 in my 89 325is. I has been working awesome for the last year with no motor-related issues until yesterday.
I went to go hop in my car to head to work and it just wouldn't start. Battery voltage is great, starter engages and all, but nothing happens. I have done a lot of troubleshooting since yesterday and am still dead in the water. Below, I will detail my setup and the steps I have taken:
S52/ODB1
TRM chip in 413 Red Label DME
e36 manual harness converted by a r3v member
(that's all I care to list, I can add more, not sure if anything else is relevant).
I originally suspected a fuel pump issue because about a week ago, my car died right after start up and I successfully restarted it about 5 minutes later...no hiccups since then til now. Now it won't start at all...
I suspected the fuel pump but I was able to jumper the fuel relay and got the pump to run. To be sure, I disconnected the fuel supply line and when trying to crank, filled a quarter of an empty water bottle. I also removed and inspected the pump...looks OK. Also, I can smell gas every time I start so I believe fuel is making it to the combustion chamber.
I suspected spark, so I replaced my plugs. Nothing happened yet again. I checked for spark by grabbing an old plug, removing coil #1, placing it on the plug and grounding the plug to the shock tower bolts and attempted starting. No spark there.
I then read on here about possible difficulties with the DME and/or crank position sensor. I overnighted a crank position sensor and still nothing...it had the same resistance as the one I removed, ~570. As for the DME, I believe it is good, as I have a CEL with the key in the on position. If I remove the DME, the CEL isn't present, so I know in some fashion, the DME is responsive. ICV is also humming.
I also checked the main relay and the fuel relay for functionality. Both click and have good functionality when tested.
I feel like I'm running out of options here. I don't want to purchase another DME as I am not suspicious of mine yet....but maybe. I doubt it is the fuel pump...I may try to check for spark again with a fresh plug to see if I can see a spark, but as of now, no spark from what I have checked. Relays are good...wiring was good, not sure why that would have changed....
Speaking of wiring, I also have looked over my grounds. I have a motor/chassis ground (looks good), a harness to chassis (near the diagnostic port, looks good), and another from the harness to the distro block (also looks good). I took them all off and reseated them to be sure.
I am at a loss...if anyone has anything I can check, I'd be very grateful!
Thanks guys,
Gavin
S52/ODB1
Thanks guys,
Gavin
