Intake manifold corner... melted?
  • DisgustipatedAP1
    • Mar 2012
    • 421
    Had to change my starter today (sucked, yep.) When I took off the intake manifold, I noticed a bunch of oil on the hose beneath it, which came from the right corner (to the right of throttle body.) Apparently that coolant hose has been heating up that corner of the intake manifold to the point where it's cracked open a bit (I'll take pics tomorrow).
    So... should I just JBWeld that shit shut OR buy a new M50/S50 intake manifold and then use some sort of heat-wrap on the corner so the coolant hose can't melt through the plastic again?
    Anyone dealt with this before? :D
    RIP: Delphin '89 E30 with S50 swap and lots of goodies :'(
    Then: '04 Evo 8 RS, 500 whp/420 wtq 2900 lb E85 AWD turbo shits 'n giggles
    Now: 2003 BMW M5 in Sterling Gray
  • yanal
    • Jun 2011
    • 248
    I highly doubt that the coolant hose melted the plastic !
    Pictures ?
    Sticky:True e36 one touch windows DIY
    1990 M3
    1992 Mtech (S50 + 5 Lug)
    • atldohc
      • Nov 2008
      • 359
      yeah if a coolant hose was getting hot enough to crack the intake im surprised your headgasket is not already blown. to be honest id probably just jb weld it after a coarse sanding and cleaning. maybe your car will run like a beast now after fixing this vacuum leak. its also not necessary to remove the manifold to change out the starter
      • ak-
        • 12422
        I think I know what you're talking about and assume the intake manifold was notched a little on purpose to clear your brake booster.
        Take a picture
        1991 325iS turbo
        • Cyrix2k
          • 593
          It certainly didn't melt. I took a torch to mine and they don't melt... they're either on fire or solid, and it takes a lot of heat for them to ignite. Anyway, if you're NA JB weld will work fine.
          1997 540i/6 - stock
          1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
          1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
          • Van Westervelt
            • 9365
            I want to see this
            • DisgustipatedAP1
              • Mar 2012
              • 421
              Take a picture
              Yep it was notched a bit. I'll take a pic today.
              What is the alternative way? As far as I can tell, the only other way would be to make a train of extensions and run them from the bottom up to the bolts on the starter... thing was a bitch to get to even with the intake manifold off, I can't imagine trying to do it with the manifold on.
              • scottinAZ
                • Dec 2009
                • 1312
                Ahhh, the manifold takes like 10 minutes to get off, and makes starter access sooooo much easier. As for melting a hole in it, good luck, dont believe its possible. that thing is some tough stuff....
                I saved 15% on my Bimmer parts by switching to ...
                • blackhawkimpact
                  • 2415
                  • surebimmer
                    • Jan 2004
                    • 978
                    A new manifold is like 60 bucks. Replace it. And post a picture your old one.
