ok, Its finally time to ditch the engine driven POS fan, and the stock electric aux fan. not quite getting enough cooling power out of the fans during HOT (112+ degree days) with the AC on. I slowly start to creep up both during idle and during higher speed runs (70+). decided to go with a 2400cfm Spal 30102048 in pusher paired with a 1200 cfm Spal 30100400 pulling.
Is this setup likely overkill with an M50 and full AC?
My intentions are to wire the big fucker through the existing high speed wiring, and the smaller fan through the low speed circuitry. I have already gone single speed on the existing aux electrical fan, so will only be running single speed for both the fans, with a staged kick on temp (based off the thermo switch and the AC demand)
