how much would a refurbished set go for? how much would it effect the price if its coated with ceramic paint?
e36 m3 s52 obdII headers
Tags: None
I thought they were worth like $100? I welded mine shut on the o2 bungs and air injection ports to use on my E30.RIP: Delphin '89 E30 with S50 swap and lots of goodies :'(
Then: '04 Evo 8 RS, 500 whp/420 wtq 2900 lb E85 AWD turbo shits 'n giggles
Now: 2003 BMW M5 in Sterling GrayComment
If you are not running the SAP and such, yeah it is.
My price reference comes from the part, Jet-Hot or similar coating, and having the mounting surface decked. That's what I'd expect to be done to call them refurbished and coated.
If you are gonna spray them with brake cleaner, then hit them with a rattle can from AutoZone, then yeah $100-150 is more likely.Comment
what if it was redone inside and out, done by a proformance shop, and then powder coated with ceramic header paintComment
What do you mean "redone"?
And, if you mean cleaned and mounting flange surfaced, and coated, I already said, $200-250 would likely be where your market is.Comment
I paid $125 for a set. They were welded and bead blasted.‘Tis by the grace of God that my cars run!Originally posted by LJ851kingston is the play by play announcer for this thread.
Siobhan's Build Thread - UPDATED!Originally posted by unloadedak#teamross
