CSB backwards with early model
  • Rugbyfan
    • Jun 2011
    • 286
    I have an '87 zf/s52. I currently have a 96-99 m3 driveshaft and new, early style CSB (<08/87) waiting to go in to replace my current DS. is it still correct to mount the CSB backwards, even with the EARLY style? seems like it wouldn't be able to go onto the mounting bolts in the body. Can anyone with the early style chime in on this?
    "Broke into the wrong God damn rec room, didn't ya you bastard!"
  • scottinAZ
    • Dec 2009
    • 1312
    early csb is different than late model. you will have to improvise
    I saved 15% on my Bimmer parts by switching to ...
    • Rugbyfan
      • Jun 2011
      • 286
      I have the csb in my hand. I think I'll just have to run it as is
      • 328ijunkie
        • May 2007
        • 3961
        If youre running E36 driveshaft install it on the driveshaft backwards.
        Check Us out on Facebook
        Full Product Line Tuning
        • treff-7
          • Sep 2009
          • 345
          you need to install it backwards. otherwise the driveshaft won't be straight. ask me how i know... it's not about the holes not lining up. if you look at the CSB it is not centered on the bracket. it needs to be shifted towards the passenger side i believe.
          • Rugbyfan
            • Jun 2011
            • 286
            thanks guys, that makes perfect sense now.
