Halp identifying some M50 vanos wires plz
  • shiboujin
    • Feb 2006
    • 2791
    I got an OBD1 M50 wiring harness with no labels. So I get to wander around figuring stuff out. The various ETKs have different wiring colors from what I've found (http://wedophones.com/BMWManualsLead.htm)
    Here's what I got:
    brown - brown/red = coolant temp to ECU (not cluster)
    blue/green - red white = vanos plug
    yellow/white - green/white - red/white = ICV
    red/yellow - brown/black - brown = ICV
    There's 3 plugs where I have no idea what they go to:
    green/brown (single wire). Evap maybe? but each ETK has that as 2 wires
    green/white - Yellow/blue. This one IIRC is also off the same long wire for the MAF or O2 plug
    brown - brown/yellow. No idea with this one.
  • e30rapidic
    • 2167
    I'll put down what I have on my S50 but beware the wire colors could be different over the years and what works for me may not be what works for you. Best to read the manual and trace backwards from the pinouts or C101 connector.
    Originally posted by shiboujin
    Here's what I got:
    brown - brown/red = coolant temp to ECU (not cluster) ok
    blue/green - red white = vanos plug ok
    yellow/white - green/white - red/white = ICV ok
    red/yellow - brown/black - brown = ICV this is TPS on mine
    green/brown (single wire). oil pressure sender
    brown - brown/yellow. are you sure its not brown/violet - brown/yellow?? that's the coolant gauge sensor
    green/white - Yellow/blue. dunno on this one
    '87 325ic, powered by S50.
    • shiboujin
      • Feb 2006
      • 2791
      My b. I meant TPS for the second one. Thanks for the clarification. Could be brown violet. Lots of oil on the wires.
      Thanks for the input!
      • SwiftE30
        • Jun 2010
        • 998
        Hope this helps. Someone gave this to me and it really helped.
        oil pressure sensor BRN/GRN or BRN/GRY
        front coolant temperature sensor (ECU) BRN/RED BRN
        rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
        crank position sensor YEL
        cam position sensor YEL RED/WHT BRN/ORG
        VANOS solenoid RED/WHT GRN/BLU
        knock sensor, 1-3 BLK NCA DME PIN 70
        knock sensor, 4-6 BLK NCA DME PIN 69
        throttle position sensor (TPS) BRN BRN/BLK RED/YEL
        intake air temperature (IAT) sensor BRN GRY
        idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
        Evaporative emissions valve BRN RED/WHT
        1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
        • shiboujin
          • Feb 2006
          • 2791
          You were spot on sir. I still don't know what that last plug is. It's the 2 prong connector right off the MAF plug.
          • Roysneon
            • 4505
            Iirc the evap plug comes off of the MAF.
            Originally posted by mbonanni
            I am a pursit now.
            • shiboujin
              • Feb 2006
              • 2791
              sounds like an odd place for that. but makes sense.
              • Roysneon
                • 4505
                I kept looking for the TPS sensor to be there, seemed more logical. I'll double check later when I'm working on the car.
                I am a pursit now.
                • scottinAZ
                  • Dec 2009
                  • 1312
                  TPS is three pin connector, Cannister purge valve is 2 pin on the same harness as the maf.
                  I saved 15% on my Bimmer parts by switching to ...
                  • shiboujin
                    • Feb 2006
                    • 2791
                    well that's amusing. I guess I could hook that back up for inspection lol.
                    • SwiftE30
                      • Jun 2010
                      • 998
                      yeah the one that is closest to MAF connection is for the evap valve. if you have it just plug it in and let the other tubes from it just sit there. i dont have my charcoal cannister hooked up and no problems.
                      please correct me if i am mistaken on this.
                      • shiboujin
                        • Feb 2006
                        • 2791
                        sounds about right. I'll just let it dangle.
