Details: OBD-1 s52
I was previously running an OTS TMS chip for my s52. I just went outside and swapped injectors, my TMS for a TRM chip and went to a 540 MAF. prior to the install I pulled the fuel relay (0 332 019 456) and turned the car over to relieve pressure. it stumbled for a few seconds and then died out. I then swapped the injectors. A good amount of pressurized fuel was still in the rail but the install went smoothly. They are all seated in the manifold and each injector is clipped into the harness. When I went to turn the car over, no fuel at all. It sounds like the fuel pump is not priming. The chip is correctly oriented and I have no codes. I'm lost
