My e30 has an S52 swap paired with a ZF 320 transmission from a 97 M3.
For whatever reason the PO left the slave cylinder from the old Getrag in the car. The result is a clutch engagement point that is millimetres off the firewall and a "wap wap wap' kind of noise when the car is in neutral and the clutch pedal is not depressed.
So I ordered the appropriate slave for the ZF320 and had my shop try to swap them out. They can't seem to tell me what exactly the problem was, but the claim to have had plenty of trouble bleeding the system and for what ever reason "it just didn't work". That being said, I asked afterwards and they didn't use a power bleeder.
According to the PO there is a new:
E36 Sachs puc sport clutch and pressure plate
OEM new flywheel bolts
Sachs throw out bearing
E36 m3 drive shaft
Pilot bearing
Resurfaced flywheel
Has anyone else had issues with their slave after a s52/ZF swap? Any idea what the problem could be? Might it simply be that the system was not bled properly? Might the flywheel have anything to do with the issue? I'd love to find a solution without having to drop the transmission if possible.
Any input would be appreciated...
E36 m3 drive shaft
Pilot bearing
Resurfaced flywheel
