I've got an '89 325i with an m50 swap.
Its primairly a track car so I've removed the heater core and no longer have hot coolant going into the cabin. All that is needed is a hose from the tank to the back of the water pump. You still need to route it back and then up in a "U" shape becuase the air intake / alternator gets in the way. Right now I have two plugs in the heater hose and don't feel good about that solution.
I measured the both ends, tank and the back of the water pump, an its about 25mm or ~1in. Unfortunately the heater hose availabe at NAPA kinks when you try to bend it the way that the original formed hoses used to run. I am also having trouble finding 1in 90 or 45 barbed bends.
Let me know if that's not explained clearly.
What is everyone using?
