im hoping to run air conditioning on my m50 swapped eta.  the bracket that holds the compressor onto the block has six bolts,  two of which are behind the crank pulley.
i know the proper way to set this up is to use all six bolts and remove the crank pulley. my question is is it safe to only use the four easily accessible ones?
the four bolts pin the bracket to the block and prevent side to side movement where as the last two prevent forward and rearward movement. the bracket seems pretty damn snug but i figured id see what r3v says.
