Not a how-to or a tutorial here, but just wanted to share the difference made in the performance by changing out the seals.
Cost was minimal, Time took about an hour, and the difference in running and performance was a bit surprising.
Old Vanos had about 150K on it, and will self retract with no help other than gravity now that the unit is out of the car. Musta been leaking like a son of a bitch when in place. seals show almost NO friction when manually moving in and out of the piston bore.
New reman unit is stiff, but not hard to move, and holds position when moved.
Used the Beisan kit for those interested. Well worth the investment
