Manually turning the engine
  • Beej '86 325es
    • 2639
    Any tips from the 24V swap guys?
    I don't have enough clearance from the radiator to squeeze in the breaker bar once I get the 22mm socket on...even with a universal joint.
    I also tried an open-end 22mm wrench, but can't get enough of the wrench on the shaft without it slipping.
    I swear I've done this before, but I can't for the life of me remember how!
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
  • BBDirtbiking
    • Apr 2012
    • 323
    Jump the starter.
    "Bayerische Motoren Werke - freude am fahren."
    Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
    • Beej '86 325es
      • 2639
      I need to get it at TDC, I'm doing a leakdown test.
      -Brandon
      '86 325es S50
      For sale:
      • jrdeamicis
        • Nov 2008
        • 956
        offset open / box 22mm.
        Past Car : E30 S50 6 Speed 5 Lug 3.73
        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
        ___________________________________________
        BNB Designs
        Engine Swaps, Fabrication, Innovation, General Repair
        Richmond CA
        Julian 848-248-8029
        • e30rapidic
          • 2167
          loosen or take the spark plugs out first.......
          '87 325ic, powered by S50.
          • Beej '86 325es
            • 2639
            Perfect. I don't have one of those, I'll have to pick one up tomorrow.
            Thanks!
            -Brandon
            '86 325es S50
            For sale:
            • Beej '86 325es
              • 2639
              Well, the offset wrench was still too big, but I found this nifty thing on clearance at Harbor Freight in a set of 4 sizes ($5 on clearance). It just plugs into the socket and allows you to put an open end wrench on it!
              -Brandon
              '86 325es S50
              For sale:
              • !kid
                • 1362
                pull plugs out put in gear and roll car/ turn drive shaft.
                :borg:
                • EyExR
                  • Jan 2011
                  • 959
                  I usually just use an adjustable wrench with a long handle.... leaving the plugs in
                  My 325iX DIY Threads:
                  Front Wheel Bearing Replacement
                  325iX Rear Subframe Bushings and MUCH more w/pics!
                  325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                  • M3PO
                    • May 2012
                    • 537
                    Pull the plugs and roll the car in 5th.
