hey guys finsihing up my s50 swap with zf tranny and i have the e36 slave cylinder in there but do not have the line that runs into the slave into the rubber/braided hose to the master cylinder, would i use the e30 one or the e36? i got a braided clutch line from uuc but i still need anpther line that runs from the slave to that line and idk what to get the e36 or e30? any help would be appreciated
what slave line do i need?
Tags: None
e36 2 piece line or e30 1 piece. The e36 line has a hard and soft portion, its integrated in the e30 one
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno Thread -
Ok so both work? I thought they wouldnt match up to another to either the slave or the mc but ok, and if anyone has one for sale Im interested mine had a hole through it when I took the engine out and now I can't find the pressure lineComment
im using the e30 one, no problems!
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
