m50 low compression repair Q
  • kylebes1
    • May 2004
    • 2804
    Car:
    1995 525i five speed 258k miles
    Im getting low compression numbers on 4 cylinders and blue smoke at start up and under power... not to mention lack of power
    Would you think I could install new ring on the engine or m54b30 internals, or would you think its the cylinder walls that have worn out?
    easy option is lower mileage m50 or m52... just looking to keep my daily driver on the road.
  • scottinAZ
    • Dec 2009
    • 1312
    you wont know if a re-ring will help until you tear into the motor.
    Best bet for a daily driver is to get a new motor. Time to replace will be about one day.
    I saved 15% on my Bimmer parts by switching to ...
    • greyis89
      • 230
      Valve seals a posible culprit for blue smoke?
      • MaksV
        • 1042
        pretty hard to kill those blocks. Honestly might just be valve seals.
        CHEAP REBUILT INJECTORS
        Need Quality Brakes? BimmerBrakes has it!
        For anything Else go with BluntTech!
        • kylebes1
          • May 2004
          • 2804
          I always thought it would be nearly imposible to messup these blocks.
          Valve seals would not attribute to low compression values, would they?
          • !kid
            • 1362
            do a leak down test to pin point the leak. could be valves not sealing, youll pay about
            200$ for a good head rebuild. if your on a tight budget just find a known good motor.
            you are correct, they would not. but a poor sealing valve seat would
            :borg:
            • Roysneon
              • 4505
              Basically it seems that to find any real answers you'll have to take the head off.
              Originally posted by mbonanni
              I am a pursit now.
              • BBDirtbiking
                • Apr 2012
                • 323
                A leak down test will help you know what the real issue is...
                If they are leaking from the valves bad, hit the tops with a screw driver and a hammer while under air to make sure nothing is clogging them when doing your test. If they still leak, probably found your issue.
                "Bayerische Motoren Werke - freude am fahren."
                Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
                • kylebes1
                  • May 2004
                  • 2804
                  Its like going to the dr for a cold. I knew what I should do now I'm kicking myself
                  • FredK
                    • 14763
                    You can do a wet comp test, where you put a tablespoon of oil down the problem cylinder. If comp goes up a lot, it's the rings. If it doesn't, it's probably the valves.
                    • kylebes1
                      • May 2004
                      • 2804
                      That sounds great too! Good technique
