Not another wiring harness thread! (c101)
    Currently converting my engine harness which has a late model c101 on it from the previous owner, to a early model c101.
    got everything on the early model square c101 hooked up except i have a few wires left over on my late model c101
    wires are: pin 14 - black/white - ??
    Pin 15 -green/black - ??
    Pin 16 - white/black - diagnosis for airbag
    my etm tells me what pin 16 is but not the other two. early models have no airbags so i guess im just blocking this wire off. how about the other two? my motors from an e34, or atleast my wiring harness is if that helps any.
    I think pin 14 is the oil level and 15 is for the starter but the early models did not have this wire, they only had a three wire starter. i believe it is some kind of ground or something?! http://www.akgmotorsport.com/e30convpins.html
      so will my check panel be constantly illuminated for oil level if i dont use pin 14?
        (may not be helpful)
        In the E36 cars at least the green/black is the wire for the unloader relay
        Black/White would be a speed signal.
        Trying to make the world a better place, 6 TB at a time.
        http://abloriginalparts.com/
          from what ive seen, wiring color doesnt really mean shit haha, even from e30 to e30 theyre all different.
            Wrong.
            Check Us out on Facebook
            Full Product Line Tuning
              Originally posted by 328ijunkie View Post
              Wrong.
              whats wrong? :(
                wires are: pin 14 - black/white - VSS
                Pin 15 -green/black - Starter Unloader Trigger
                  bingo
                  Nice to be right once and a while!
                  Thanks for confirmation.
                    where does the VSS wire hook up on an early model then? i dont believe i have any other wires left in my early harness. and what the hell is a starter unloader trigger?
                      Back of cluster.
                      And on an early model, unloader trigger is nothing for you to worry about.
                        Back of cluster.
                        thanks a million man, really appreciate it. is the back of the cluster labele for where the vss connects? also do you suggest extending the wire in order for it to reach?
                          No label. I use the CC plug on my customers harnesses.
                            thanks man, for your help ill definitely buy my e30 m3 wiring cover from you! cc plug = cruise control correct?
                              Correct :D
