Hey r3v,
I recently purchased a late model e30 with an m50 swap performed that was not running. I got it up an running and have been driving it around as a DD ever since and now I've run into some problems. I wanted a more stanced out look so I temporarily purchased lowering springs offer a r3v member (bav auto springs to be exact) until I could afford some fully adjustable coilovers. It seems ever since that I have had a HORRIFIC vibration from 35 and up to oil speeds including 120. I checked the drive shaft out at work, I'm a mechanic, and found vulcanized rubber in the carrier bearing to be torn so first thought was this was the issue. I replaced it with one from bma and as soon as I got on the highway it was even worse. I checked me geibo it was brand new with the car and seems to be fine (no tears) and ive pryed on the u-joints to see if there was any play and nothing so my only thoughts are this... unbalanced drive shaft (unlikely because nothing appears damaged on the shaft and when I first started driving it there wasn't a vibration, a frozen trunnion on one of the u-joints (still seems unlikely), an incorrect driveline angle due to the swap, or an extremely incorrect pinnion angle from the lowering kit. I'm leaning towards the pinnion angle however I'm wondering if anyone else has experienced a similar issue after lowering there e30 with springs and how I can shim the diff to correct it. Any and all help is appreciated!!!
