after my swap i have little to no brakes my set up is a 740 booster and a e36 325 MS ... brakes are bleed pedal is hard yet when pushing brake pedal the car will not stop , it barley slows down... any advice?
no brakes
Tags: None
Sounds like your booster isn't working. It might be bad, or you might not have plumbed in a vacuum line properly. Make sure you have a check valve on the vac line as well, as that can also be an issue.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpic -
I'm having same issues same set up as yours 740i brake booster and e34 brake master cylinder what it that you fixed your problem pls help!Comment
