Engine cranks but no doesn't start!
  • Classicoe30
    • Apr 2012
    • 205
    Help 24v swap on my e30 325i ! It cranks but doesn't start at all! All connection are done properly! Have fuel and spark, can crank sensor be still be bad? I have m3 s52 cams but didn't change cam sensor, is it bad or do I need an m3 cam sensor? pls help ! Thanks in advance!!
  • DesertBMW
    • Aug 2011
    • 1040
    if you got spark then sensors are good, looks like DME is not triggering the injectors, try to start it with unopened red sticker 413 dme
    • Classicoe30
      • Apr 2012
      • 205
      Ok I will by tomorrow thanks!
      • Classicoe30
        • Apr 2012
        • 205
        Any other suggestions you might know I should try thanks in advance!
