What I want is a booster that:
Bolts directly to the firewall
Needs no shortening/threading of the rod
Uses a non remote type brake reservoir.
I want to be able to use either the early 318, late 318 or iX master cylinder and its matching reservoir.
I'm currently running an iX booster that is crapping out on me. I had to remove the spacer that goes between the and firewall and drill two new holes to mount it up to make it clear the intake and for the brake res. fit behind the throttle body and intake boot.
