So everything is in and from everything I can see it is in correctly. Turn key, cranks and cranks, but red 413 DME is not telling injectors or spark plugs to fire.
So... I checked the crank sensor ohms at the DME connector (88 pin female type that plugs into DME, pins 16/43) and I got 530 ohms, well within spec.
So... I did the stomp test and i get a mysterious single blink. From searching, code 1000 signifies the end of the code sequence. At this point i clear all stored codes and re-try the stomp test, code 1444 is flashed. All clear. Try starting her again and get 1000 after trying the stomp test again. I'm wondering why it shows 1444 before cranking and 1000 after. Weird?
Also, pin 1 & 38 of the ecu are supposed to ground the BR/GN wire to the fuel pump & O2 sensor relays, respectively. This isn't happening. I have the fuel pump relay removed and a jumper wire in it's place to provide pressure.
Confirmed fuel pressure (loosened clamp at filter a couple turns and started pouring out), lack of ticking fuel injectors or fuel smell, and no observed spark with coil and plug resting on valve cover. All make me think that the CPS is bad. However, as I stated it's reading within spec.
All grounds at the DME connector have been checked (good) and I tried swapping in a different red 413 DME (no change). The IAC is buzzing and i'm getting an audible click on the main/DME relay.
Please help. Why is my DME getting power, but not firing the injectors, plugs, or fuel/O2 relays? Bad harness?
