m52 running really hot
  • limp mode
    • Jun 2012
    • 117
    Hey im kinda a noob with this motor so bare with me (coming from vw) i just picked up a e30 swapped with a m52 and i was driving it tonight and the temps just kept climbing and stopped before hitting red. i turned it off and it kept climbing up.. What should i tackle to make sure the temps stay in the middle and cool. fan clutch,Waterpump,thermostat?
  • Boise
    • 212
    Do you have a fan clutch? Most 24v e30's dont because of clearance with the radiator and opt for an electric fan instead. Maybe a dumb question, but worth asking.
    How long were you driving before it got hot?
    Did you heat up more sitting and cool down when driving?
    Did you check your coolant level?
    • Roysneon
      • 4505
      Do you know what radiator and fan setup you have? Bleeding the system again is free so I'd start there. How about a pic of the engine bay that shows the radiator and the fan setup?
      Originally posted by mbonanni
      I am a pursit now.
      • limp mode
        • Jun 2012
        • 117
        it got hot after like 10 mins of driving and yea it did heat up more when i stopped. yea it has coolant but its not 100% full.
        hopefully this helps
        • DesertBMW
          • Aug 2011
          • 1043
          sense you are new to BMW, I got to brake the bad news to you. M50 engine is known to have cracked cylinder heads when overheated few times.
          • limp mode
            • Jun 2012
            • 117
            its a m52 and obviously bad shit will happen when overheated haha. it didnt hit red it was chillin at the 1oclock area
            • Ivan2terrible
              • Aug 2012
              • 6
              Is ur block Aluminium or cast.. Cause if it's Ali then it prob ran hot and is now warped.. Try source m50 block.. Unless ur head is also cooked
              • 10Toes
                Me Father Was A Tree
                • Jan 2008
                • 61222
                Go back to VW's
                • M-technik-3
                  • 18946
                  First things first is there fluid in the coolant system?
                  If not raise front end ie on a small hill. Fill coolant system up with proper mix to proper level. Allow car to get warm ie need the thermostat to open to fill the system completely. Put cap back on check for leaks and so forth.
                  Do a drive check and see if it climbs again.
                  I see a fan so If you can put the shroud back on the radiator for proper air flow through it.
                  • Bimmerguy91
                    • Jul 2012
                    • 982
                    Either that or swap to a large electric fan.
