Help Diagnosing Rear Vibration
  • down_shift13
    • 44
    Hi, I just recently finished Installing my rear suspension. I took down the whole subframe and replaced the subframe bushing, rear trailing arm bushings, and half shafts plus changed to LSD. In addition to that, I also did the center bearing and Guibo. Now, I have a vibration coming from the rear which is there around 30 mph. I dont notice them at speeds higher than that. Any Ideas? Also, would I need an alignment since I changed all if those parts?
  • down_shift13
    • 44
    Ooops, just realized I posted this on the engine section. How do I change this?
