E34 throttle cable fitment?
  • cormier
    • 380
    So I have an e34 throttle cable for my s52 swap, but it looks like either the cable or throttle body piece is wrong. I dont see a bend in the cable that i hear talk of. Any insight? Pix of cable and tb
    Thanks!
  • bzboardz
    • 1096
    here is how mine looked like
    • BBDirtbiking
      • Apr 2012
      • 323
      My cable for example. Same as bzboardz.
      "Bayerische Motoren Werke - freude am fahren."
      Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
      • e30rapidic
        • 2167
        e34 cable wouldn't work for mine, I had to go to an e36 one. Mine is OBDI S50 though
        '87 325ic, powered by S50.
        • 328ijunkie
          • May 2007
          • 3961
          Ive used the E34 cable in every swap ive ever done without issues. And OP thats not an E34 525i cable.
          Check Us out on Facebook
          Full Product Line Tuning
          • cormier
            • 380
            What is the p/n for that bendy cable? The one I found searching, for e34 m50 looks just like mine in the diagram -- no bend. and it doesn't adapt to my TB
            35 41 1 160 609
            http://realoem.com/bmw/showparts.do?...35&fg=10&hl=86
            mine looks like e30rapidic 's with the straight metal piece where it attaches-- again a no go for the curved TB bracket
            edit: looks like its obd2 vs 1 issue, I have an obd1 TB at home i believe, I'm going to try that with a new cable ordered...prove the part diagram false lol. I must have gotten a different one the first time.
            • jaywood
              • Jul 2010
              • 4528
              Will an obdI s50 use the e34 cable? Or is there a better alternative?
              • cormier
                • 380
                I'll let you know lol -- obd2 is what I have pictured I believe and it mounts differently to the cable
                • lbreevesii
                  • Aug 2009
                  • 412
                  I used the E34 as well, but it is a bit too long. I just had to play with the routing.
                  I don't always wreck cars, but when I do I wreck them into trees.
                  91' 318is S50 swap - The Black Widow
                  • dball4
                    • 560
                    http://www.pelicanparts.com/cgi-bin/...9%281991-95%29
                    Here ya go. Just did this for mine. Worked perfectly
                    1989 M3
                    2008 135i 6sp
                    • cormier
                      • 380
                      Thanks. So I have indeed ordered the correct cable which is good. I'm still wondering about the TB side. I'll know
                      Monday.
                      Does anyone happen to be running my style TB (obd2?)
                      • BBDirtbiking
                        • Apr 2012
                        • 323
                        I am running OBD2 throttle body with the 90 degree bent E34 cable. It held my throttle open too far at idle but a little adjustment to the rubber holder and it was good.
                        • cormier
                          • 380
                          Thx dude. My confusion was only that the cable I have has a straight piece that doesn't fit in the obd2 holder... I think the e34 90 cable should be good then :)
                          • evoDRichie
                            • Jan 2010
                            • 1743
                            i have a e34 intake man. and my e30 cable worked with slack to spare no bending of any kind... is the throttle body diff on e34?
                            • e30shmobberr
                              • 1934
                              i have obd1 s50, and e34 cable. no problems
                              Patrick - IG:niicknac
                              RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
