Looking for some maintenance info. Keep in in mind, it's a race only motor.
Picked up a 60k miles aluminium block M52 for a song. It already has S52 cams. It's been sitting on a shop floor for a few years, and the only info I have, is that it was overheating when it was pulled out of the 1998 Z3 in favour of an S50. The block is fine and the head will be sent to a machine shop for a thorough inspection.
So, I took it all apart, down to the last washer, just to educate myself, it is going to be rebuilt anyway, by a real mechanic, and it got me thinking of what should be replaced/upgraded.
I am not looking for big power. I am thinking that S52 cams, M50 manifold and a tune will do the trick in order to get around 200HP at the wheels.
What I want to know is what should I replace/upgrade "while I am in there".
So far the short list consists of:
Forged Pistons
Baffle Pan
Crank Scraper
Stewart Water Pump
Bearings
What else? Don't really know much about problematic areas on these engines.
Which head gasket - stock, aftermarket?
Not sure if the chain and tensioner need to be replaced.
Etc...
Basically, what should be done to make it as reliable as possible?
Thank you.
Forged Pistons
Baffle Pan
Crank Scraper
Stewart Water Pump
Bearings
Etc...
Thank you.
