Engine running rough!
    Done with my 24v swap but my engine is running rough ! Two codes speed sensor and air temp sensor codes! Will those codes make my engine run rough? Can someone help me any tips on what to check for or has someone had the same problem and fix it! Thanks in advance !
    what air temp sensor?
    Check Us out on Facebook
    Full Product Line Tuning
      I also need to know
      I don't think those codes causes running rough, but first try to look for vac leaks..
      M20B28 Turbo
      My Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=255839
        Thanks you guys problem solve!!
