What is the reason one has to convert to the e30 rubber hose instead of using the hard tube that the m52 has?
m52 coolant tube Q
I use the metal coolant pipe on everything. the OBD1 soft line is garbage
Check Us out on Facebook
Full Product Line Tuning
