S50 swap problems
  • Fernflex
    • 264
    S50 swap problems
    I have a friend who installed an s50 on a 318is 1991, the engine was working fine before installing on the e30.
    The problem is the engine works better with the flowmeter backwards, it still has a small rough idle but after 1,000 - 1,500 rpm it opens decently. If you install the flowmeter how it goes the idle very gets rough and end up shutting down.
    We have try 2 different flowmeter and it does the same. We have check the wiring harness from the flowmeter to the ecu and it looks good everything.
    Some additional info:
    The car has no air filter or intake tube.
    The car could have bad gas, after been parked for a year.
    But it doesnt make sense that it works better the wrong way.
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
  • e30shmobberr
    • 1934
    1. put better gas in.
    2. clean afm.
    3. try again
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • 328ijunkie
      • May 2007
      • 3961
      Vac leak. /thread
      Check Us out on Facebook
      Full Product Line Tuning
      • josuemarine
        • 77
        Originally posted by 328ijunkie
        Vac leak. /thread
        Any sugestions to test this..?
        • matthugie
          • Mar 2004
          • 1810
          Smoke test is the best way, but I would start with changing the gas. Since it's been sitting for so long it needs to be changed anyway and may help with further diagnostics.
          88 325is - S52 powered
          Originally posted by King Arthur
          We'll not risk another frontal assault, that rabbit's dynamite!
          • samiam3356
            • Jul 2009
            • 1901
            haha yes, makes me laugh a little whenever I see this recommendation after seeing Jlevie say it for years.
            Originally posted by Roysneon
            $5 shipped?
            Originally posted by MarkD
            You are a strange dude, I'n not answering any more posts from you.
            • walktheboard
              • 347
              Originally posted by e30hijinks
              I move faster than "the speed of light." I'm always connected to my Blackberry and am ready to purchase at a moment's notice. I do not play games
              • Fernflex
                • 264
                I think it maybe a vac promblem because I remember the afpr was loosing pressure.
                Please Rate Me:
                ________________
                __________________
                • wastedincome
                  • Aug 2004
                  • 906
                  I've always just checked for vac leaks with starting fluid as I always for get my smoke tester in my other jeans
                  Wastedincome420@yahoo.com
                  CURRENT STOCK LIST:
                  00' e38 750iL HighLine=Highway Queen
                  92' e30 318 vert=Aint going anywhere
                  91' e34 535iM=Aint going anywhere
                  91' e34 525iA=For parts
                  92' e34 535iA=For parts
