CEL #1221 Lambda
  • driftingminor913
    • Sep 2011
    • 358
    CEL #1221 Lambda
    I ever since I have finished this swaps check engine light has been on. Can't get rid of it, just looking for some insight. I have searched other forums and others say it could be a intake leak or cracked hose. But I just did my own smoke test on it (with dry ice and a sealed container into the intake plenum) and I'm
    Not seeing any leaks. I did the stomp test and. It only gave me Code 1222?? It's on a 94 m50b25TU in a 90 325i
    Because V8
    http://www.r3vlimited.com/board/showthread.php?t=282219
    Doing it wrong since 91:wgaf:
  • Robert
    • Dec 2010
    • 3770
    rest battery . try stomp test again.
    • driftingminor913
      • Sep 2011
      • 358
      Okay wil do
      Because V8
      • driftingminor913
        • Sep 2011
        • 358
        Rest the battery and idle is up and down until I pull the pedal back then it idles all the way down and wants to die then shoots back up. Also no CEL when at idle only when on highway
        Because V8
