M50NV to M50TU Wiring Question
  • shEck3lls0
    • Jan 2011
    • 1154
    I have a 1989 325i that currently has a bad M50 NV in it. I have a donor 86 325e that was M50TU swapped that I will be using the motor out of for my 89. My question is, can I use the harness that is currently in my car or the vanos harness out of the 86? I know I will have to modify the vanos harness, but I don't know the difference between the modifications needed to do the swap in the 86 e compared to an 89 i. Any help in appreciated. :D
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
  • 328ijunkie
    • May 2007
    • 3961
    Replace the harness. Youll be doing ALOT of wiring if you dont. Vanos, HFM, knock sensors, etc are all different. And off the top of my head im not even sure if the ECU connectors are the same pinout wise.
    Check Us out on Facebook
    Full Product Line Tuning
    • shEck3lls0
      • Jan 2011
      • 1154
      Well I do have both harnesses. The vanos one was just modified for an 86 325e.
      Build Thread:
      • 328ijunkie
        • May 2007
        • 3961
        Ah, IC now. Well youll have to do a bit of rewiring as the C101 for the ETA is missing a ton of stuff vs the late models. Alot of stuff is run through the glovebox.
