As the title says the car wouldnt stay started unless I gave it gas. You know how when you start a car the rpms go up and then down to the idle point. Well my rpms just went up and then down till the car died. I say wouldnt start because it started after I looked under the hood to see if there was anything obviously wrong. The only thing I did is moved my intake(aftermarket) up just a little bit to look under. I only say that because Im not sure if it had something to do with maf I believe its called or it just "fixed" itself.
Thank you in advance
