*help* Slow start
  • limp mode
    • Jun 2012
    • 117
    *help* Slow start
    i got my e30 about 2 months ago its a m52 OBD1 swap with about 90k on the motor. so in the past two days when i go to start the car it has a slow hesitating start like almost the starter is dying? Wanted to know if that is the case or is it a ground that could be causing the issue. Help me to track the issue down. Thanks r3v
  • justin_l_
    • Jun 2007
    • 1079
    Slow to start as in turns over slow or cranks normal but takes a lot of cranking to start?
    • devon.818
      • Feb 2011
      • 2937
      get your battery tested
      wait where in md are ya, we got a interstate battery tester, if you're local swing by.
      but yeah thats what it sounds like
      • shiboujin
        • Feb 2006
        • 2791
        or bad engine ground. or bad connection to the battery
        • limp mode
          • Jun 2012
          • 117
          to clarify the car will crank and start in normal time (usally a few chugs before turning over normal) but the chugs are super slow sounds like its about to die. i think the battery is ok but im not going to rule it out. it might be a ground. is there a ground strap on the starter? were should i start to look?
          • shiboujin
            • Feb 2006
            • 2791
            ground strap attaches to the block and the frame. should be on the oil pan on the driver's side. Never hurts to add more.
            But usually, this is a sign of a dying battery.
