What driveshaft with g250?
  • JFarhanbod
    • 2151
    Figured I should post this here instead of in transmission cause most people who used the g250 would also have a m50. What driveshaft should I use? I have the auto e30 325is driveshaft and an e36 325i manual driveshaft. Does the e36 one just bolt up or do I have to get some type of frankenshaft made? Any other problems with running the g250 on an e30?
  • FredK
    • 14762
    Yes. The E36 driveshaft bolts right up. There should not be any problems running a G250 on an E30. It's not the most robust transmission, but it's pretty decent.
    • M-technik-3
      • 18946
      As Fred mentioned, they like to pop out of gear when thrashed upon.
      • Roysneon
        • 4505
        Use the manual e36 shaft, that's what I'm using. Just need an e30 csb installed backwards.
        Originally posted by mbonanni
        I am a pursit now.
        • JFarhanbod
          • 2151
          for the csb, which e30 one is it? there seems to be 2 of em. one early and one late.
          • JFarhanbod
            • 2151
            or does that depend on my car?
            • FredK
              • 14762
              Yup. Depends on whether you have an early or late car.
              • amcink
                • 788
                What preventive maintenance I can do on a G250 before it goes in (other that the seals; throw bearing etc) Do I need to do any of the solenoids?
