Stomp test in pre-88 cars
  • maneeno325e
    • Apr 2012
    • 218
    my eta is an 85 and i was wondering if when i swap it for an m50tu if i'll now be able to do the stomp test since i have a newer dme which is set up for doing the stomp test? is this reasoning correct or am i dumb?
    its correct that pre 1988 cars had no stomp test? so by adding an updated engine i should be able to stomp test?
  • e30shmobberr
    • 1934
    my 87 325is had stomp test, havnt tried with my s50.
    pretty sure all obd1 bmw's do the stomp test. its obd2 that it does not work with.
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • FLG
      • Sep 2011
      • 3165
      Think its all about what ECU you have, a example 153 ECU is 1.1 and wont be able to do the stomp test, 1.3 ECU's will and any 1.1 ECU can be replaced with a 1.3 ECU.
      No idea how it works with swaps though. I assume if the check engine light still works, so will the stomp test.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • 37832
        If your check engine light is hooked up, yes it will work.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • 328ijunkie
          • May 2007
          • 3961
          ^That.
          The ECU doesnt care what car the setup is in. Its looking at the throttle position sensor. Assuming you have a CEL wired properly and your Throttle cable is adjusted right it should work fine.
          Check Us out on Facebook
          Full Product Line Tuning
          • Beej '86 325es
            • 2639
            I've got an '86 325 chassis (probably similar wiring to yours). Most people have the E30 C101 pin 12 (BRN/BLK) connected to the E36 X20 pin 8 (GRY). I've found that my car does not have a wire/pin 12 in the harness, thus why the stomp test does not work for me.
            Just get a Peak code reader for $50. If you're working through a swap and having lots of issues, it'll read out the codes a lot faster than the flashing check engine light will spit them out.
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • 328ijunkie
              • May 2007
              • 3961
              You know you can wire a CEL easily. I wire them in all my swap harnesses for pre 87i cars.
              • maneeno325e
                • Apr 2012
                • 218
                so what is the correct way to wire it properly. im 99% sure i used every pin on my harness and dont recall anything about CEL or diag.
                • davvik
                  • Dec 2013
                  • 49
                  Bumping this thread because I'm trying to figure out how to add a check engine light to my 1987 BMW 325e.
