Easy question regarding OBDI VANOS solenoids...
  • dsobering47
    • Oct 2007
    • 697
    I have an M52 that I'm converting to OBDI and was wondering if I need an OBDI VANOS solenoid to match, as well? I'm running S52 cams, if that makes a difference.
    Not sure what part number I should be looking for...any help is appreciated.
  • bubbajan21
    • 1962
    I'm not sure if you need one, but I've got one to sell if it ends up that you do.
    • 328ijunkie
      • May 2007
      • 3961
      Only difference is the wire length. Either can be used though.
      Check Us out on Facebook
      Full Product Line Tuning
