okay ive searched but ive become lazy so i thought id start a new thread. Can i just swap my m52 intake manifold for the m50 manifold and get the adapter silicone hose and call it a day or do i have to go through with the whole obd2 to obd1 conversion. im planning on installing 24# injectors and s52 cams. would i need a bigger throttle body or dif maf? any advice or critics is welcome thanks for reading:bow:
M50 Manifold/upgrade help!
Tags: None
For the m50 manifold swap you can keep it OBDII with the silicone hose kit. I did that on my m52.
I'm running s52 cams and didn't bother upgrading to a bigger TB or maf.Comment
Yea? so how was the feedback from the engine? throttle response? im psyched for it but i dunno if i should be ehh about it or expect it to outperform. i can understand the tb or maf but i think the injectors is a must for the extra air intake? cause when i compare the m50 is HUGE and the m52 is like sucking air through strawssigpicComment
im retaining obd2. i dont really know why everyone does obd1 swaps ive read like 5 STORY BOOK threads on it i still cant see obvious pro that outweigh labor :dot: im also in the process of collecting parts for my turbo build...i have intercooler and tial 44mm wastegate i got from friends, so before or by new years i hope to have turbo either bolted on or parts assembled. looking for 350hp not really leaning to 4 as to avoid engine mods-arps HG blah blah. so like 6-10 psi as a DD any help or parts is welcome too thankssigpicComment
Until a few years ago, you could make a LOT more power on OBDI because they had not cracked the tuning.im retaining obd2. i dont really know why everyone does obd1 swaps ive read like 5 STORY BOOK threads on it i still cant see obvious pro that outweigh labor :dot: im also in the process of collecting parts for my turbo build...i have intercooler and tial 44mm wastegate i got from friends, so before or by new years i hope to have turbo either bolted on or parts assembled. looking for 350hp not really leaning to 4 as to avoid engine mods-arps HG blah blah. so like 6-10 psi as a DD any help or parts is welcome too thanks2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
if youre planning on going turbo, maybe consider obd1. I know TRM is working on obd2 turbo tuning but it's not popular yet (read: expensive).
also, if you're building an m52 with boost, skip the s52 cams. then use the money you saved to o-ring the block, get a new OE headgasket, and ARP head studs. that should be good for 10psi and 350hp on a quality tune (obd1 or obd2)Comment
hmm i see. doesnt sound like a bad idea. now what exactly do you mean oring the block? and OE HG? is tht a brand lolif youre planning on going turbo, maybe consider obd1. I know TRM is working on obd2 turbo tuning but it's not popular yet (read: expensive).
also, if you're building an m52 with boost, skip the s52 cams. then use the money you saved to o-ring the block, get a new OE headgasket, and ARP head studs. that should be good for 10psi and 350hp on a quality tune (obd1 or obd2)sigpicComment
y'all best do some reading before digging in too deep.
o-ringing is a process in which an o-ring channel is cut into the block around each cylinder bore, and a length of copper wire is placed into. the resulting o-ring engages the headgasket for better sealing.
OE just means original equipment. don't get victor reinz. buy original BMW. also, MLS (multi-layered steel) head gaskets are okay in certain applications but it can be tricky to get them to seal.Comment
OBD1 is outdated bleh for brains.if youre planning on going turbo, maybe consider obd1. I know TRM is working on obd2 turbo tuning but it's not popular yet (read: expensive).
if you are buying a real turbo setup the tuning is small potatoes in the equation.
OBD2 turbo = proper setup. Pay up to play.
obd1 +turbo is = flash back to 1995 for brains.......do you really need that ? it's almost 2013OBD1 M54/M52TU swap as a M50b25
this is the big deal. i know OBD2 is best. but as far as accesible turbo tuning, OBD1 is far more economical and convenient for most.
i was just throwing out an option for OP. obviously he is the one that needs to look at all sides of the argument and make a decision. and i personally think he has a lot of research to do.Comment
